Pattern/3D Plane??
Which is the best performer for both?
Excelleron or Quest 3D maybe? Any more worth mentioning? |
RE: Pattern/3D Plane??
synergy 90
CA models Widebody 60 is my choice for a plane that will pattern and 3D.
1 Attachment(s)
How about this plane ?
It is 775 sq inches on a 64" span- weighs under 7 lbs inc a .91 YS OK- what is it? Note : you have to be over 21 to figure it out. |
tipo?
Nope
Looks like a Runaround or a Runaway to me.
Steve |
Runaway - This is one I did for old friend -
The owner does not fly 3D but there is no reason it would not do any maneuvers -with larger surfaces Wing loading is just under 21 ozs to the foot . Having built a few of the latests ARFs -I don't see why these older designs with larger control surface won't work just as well. As far as I can tell wingloading and power counts 9 of the 10 top reasons for good performance . The rest is eyewash . |
So are they still available?
The kits are -from a local friend -- this one is on it's way to Maine - so you may see it -
I plan to be at the Bush Pilots Pattern Classic at Waterboro in August, so I will look for the Runaway. How about a contact for the friend with the kits?
ORIGINAL: dick Hanson Nope |
| All times are GMT -8. The time now is 06:56 PM. |
