RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   OS 160 prop and fuel? (https://www.rcuniverse.com/forum/rc-pattern-flying-101/3308998-os-160-prop-fuel.html)
3Don 08-29-2005 04:43 AM
Hi guys,
Here is few questions for you. For next F3A season i will use OS160FX with Perry pump and tuned pipe. I want too pick up rigt prop ir and fuel for 2m pattern plane with this engine. I gues APC 18x10 is best option for this setup. What you guys think, please share your experience about this engine.
Thanks, 3Don
fancman 08-29-2005 05:45 AM
RE: OS 160 prop and fuel?
I use a 16X10 Master Airscrew three blade. Works great. Check out this info also.
http://www.rcaerobats.net/OS160_Setup.htm
3Don 08-29-2005 07:18 AM
Thanks for reply and link, i gues it is good recomendations. But i already have 2 blade spinner, so i want too go with 2 blade prop. Also think too use 18%oil, 10%nitro fuel. Maybe will go with APC 17x13.
Greets 3Don
byoung466 08-29-2005 09:30 AM
The 16x10 3 blade master airscrew works very well, I found the speed is much more controllable w/ the Masterairscrew,
3Don 08-29-2005 09:54 AM
How much cost that prop, and where can i buy it?
fancman 08-29-2005 10:17 AM
Here is where you can buy this prop.
http://www.masterairscrew.com/
jonlowe 08-29-2005 12:50 PM
If you are flying 2 blade, 17x13 APC works well with 15% nitro fuel, Perry pump, Mueller header and Aeroslave pipe.
Jon Lowe
