RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   cyclone build (https://www.rcuniverse.com/forum/rc-pattern-flying-101/3374543-cyclone-build.html)
Chris-B-chips 09-19-2005 09:16 PM
cyclone build
1 Attachment(s)
Hey guys,
Heres my build thread of the cyclone which is exclusive to Austrlia. The Cyclone is designed and mostly built be master builder John Payne. The Cylone is built straight as a die and flies like nothing i've ever flown! Snaps stop on a dime and the rudder power is insane!
I will be running all JR equipment:
elevator: DS8455 super speed servo
Rudder: DS8411 high torque servo
Ailerons: 2x 9411 midi size servo
Reciever: R900S PCM reciever
Battery: 1100mah Nicd, may go lithium
Motor: OS 140RX with Hatori high rise header and tuned pipe.
Here are some picture of it so far and one of the backup model i'm flying at the moment also powered by OS 140RX and the exact same setup. I only started taking photos halfway through so all the seems have been sanded and filled which was alot of work!!![:'(][:'(]. i will post some picture of the wings and the colour scheme i have planned for it later. I have also included a picture of all the central hobbies goodies!
the_madgenius 09-23-2005 08:58 AM
RE: cyclone build
Hello Chris, i read your article above , and will let John know it is in here. I see him every week, with his Cyclone, and yes i agree it is an awesome aircraft,but dont praise John too much , we have to fly with him, dont want a swelled head as well to contend with. But all jokes aside i am sure you will be more than happy with the Cyclone
Regards the_madgenius
Chris-B-chips 09-23-2005 05:08 PM
RE: cyclone build
LOL, :D thanks madgenius.
BTW, plane is coming along. finished installing spruce on the rudder tray to make it stronger. Got the rails in for the elevators L bracket, got all the trays glued in. should be painting this weekend or next. probably next weekend though. Covering is on its way from Sydney.
PeterNzen 09-24-2005 04:26 AM
RE: cyclone build
Hi Chris, looking good. Just remember... every gram counts :-). Now if I can just get my next one up to that stage I'd be right. Hope you guys are going well.
Chris-B-chips 09-24-2005 04:42 AM
RE: cyclone build
Hey Peter, Yeah i'm a bit worried i built the rudder tray a bit heavy but i suppose as long as it comes in under 5kg i'll be happy with it My OS has plenty of power to pull it around;). And it'll be better in the wind.:)
j payne 09-24-2005 05:17 AM
RE: cyclone build
Chris
Remember to keep it light the Cyclone flies best if kept under 4.8kg your rx140 will strugle if it gets heavy especially
in the wind go easy on the paint on the fuse a light model always flies better even in the wind
so remember KEEP IT LIGHT
John
Chris-B-chips 09-25-2005 01:18 AM
RE: cyclone build
Will do John. Every thing i've made has lightening holes in it.
troyhm 09-25-2005 04:31 AM
RE: cyclone build
Hi chris
Who makes/sells the cyclone in Australia ? Look really nice.
THANKS
Troy
Chris-B-chips 09-25-2005 06:38 PM
RE: cyclone build
troyhm, John Payne (j payne) up in Yeppoon designed and builds the cyclone.
troyhm 09-25-2005 10:02 PM
RE: cyclone build
Hi Chris
Was it a kit ? How much was it ?
do you have contact information for john payne at all
thanks
Troy
Sorry everyone stupid me didnt see that jpayne had actually posted here
Ryan Smith 09-26-2005 12:18 AM
RE: cyclone build
Beautiful airplane Chris. Is it molded balsa? I've seen the Cylclone some around (on the net), they look good.
Chris-B-chips 09-26-2005 03:03 AM
RE: cyclone build
Its a vacuum moulded fuse which is made up of ( John correct me if i'm wrong) 3/4 oz cloth, 1/16th balsa, 2oz cloth sandwich. the wings are balsa sheeted foam core, bassicaly your typical pattern wing. this model is amazingly strong from what i've seen (Half throttle snap in a verticle downline![X(]). I'll try and get some more pictures of the progress, but certain things like school and composite arf extra's tend to get in the way of much progress[8D].
troyhm 09-26-2005 03:20 AM
RE: cyclone build
Hi Chris
Is it rude to ask you how much the kit cost you ?
I am in melbourne
Troy
Chris-B-chips 09-27-2005 12:49 AM
RE: cyclone build
Sorry I missed your question, No its not rude at all[8D] I THINK the kit was $800, the competition balsa to sheet the wings, wing tube, motor mount, nose ring and F3A wide under carriage cost around $450 , and then another $600 to get it built ready to cover and paint stage.
Vortec 09-27-2005 06:19 AM
RE: cyclone build
1 Attachment(s)
Looks like you are well on your way for the national team now Chris..Hope John doesnt mind making airframes as i'd like to get one of these when i can STEP up to a 2X2..
For now i have to settle with a smaller Cyclone that was given to me from a club member.Should be going by Coolum.
Keep up the thread and your flying..
Darran.
Chris-B-chips 09-27-2005 05:11 PM
RE: cyclone build
That looks like it'll fly nice. It'll be good to see you at coolum[8D].
Stiks 09-28-2005 03:02 AM
RE: cyclone build
When is Coolum on??
Stiks 09-28-2005 03:06 AM
RE: cyclone build
Vortec 09-28-2005 03:33 AM
RE: cyclone build
November 19-20 if i rember right.
GlennO 09-28-2005 07:43 PM
RE: cyclone build
Chris,
The cyclones are a great plane you'll love it. I had two, lost'em both in mid-airs.
In fact, you would have seen my second cyclone at the masters at Shepp meet it's maker.
Sad day that, it was it's first comp. I had a 140RX in mine and it flew great.
I've moved on to pinnicles now, can't get'em built quick enough to keep up with the mid-airs.
Good luck at the imac on the weekend
GlennO
Chris-B-chips 09-29-2005 12:47 AM
RE: cyclone build
yeah i remember[:'(][:'(] shame, your cyclone was easily the best finished cyclone i've seen.
Vortec 11-08-2005 04:22 AM
RE: cyclone build
Hay Chris, hows the Cyclone comming? Your not spending to much time with Peter's to finish your own off are you?
I should have mine finished by tomorrow.Going to fire it up to give the engine a few tanks and to iron out any bugs as my throttle linkage setup was BS.. Why cant they make four stroke carbies on the front like the REAL engines..
Cya..
