Retract Servo
Will the Futaba S136G Compact Retract Servo work with an Airtronics Radio?
RE: Retract Servo
Should if use an adaptor.
RE: Retract Servo
If you are using a current recevier that has the Z plug it will be fine. You may have to trim the little tab off the servo like the JR guys do. If you have an old style reciever the plug won't fit and the wiring is different. Then you will need the adapter.
RE: Retract Servo
Thanks, Anthony.
I have the new style Z receiver, the setup is RD8000 which is their newer 8 channel system. I just have not seen a retract servo for the Airtronics, or at least one that is advertized as a low profile retract servo with 180 degree movement. DS. |
| All times are GMT -8. The time now is 05:29 PM. |
