RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Genesis ARF build, glow version (https://www.rcuniverse.com/forum/rc-pattern-flying-101/3505029-genesis-arf-build-glow-version.html)
Gregg G 12-22-2008 09:19 PM
RE: Genesis ARF build, its here.
Freddy,
Was there a false rib attached to the end of the tube on the outer wing panel?
Greg Grigsby
Freddy 12-24-2008 10:46 AM
None that I could tell hence the problem. All I could see was foam. Unless the rib had a cutout to pass the tube thru.
Gregg G 12-24-2008 04:38 PM
That's a BIG problem. You have to have a false rib to support the outer half or else!
Greg Grigsby
You should check it out further. Was it an ARF?
