E OTOP
have anyone use hacker C 50 14 XL with MAS77-O-flight speed control !! any luck with the setup ? I'm trying on the OTOP put having flight it yet!!! what size is the prop will work well with this set up. thanks
RE: E OTOP
I used this setup in two planes last summer. Worked well. Though I had one esc turn to charcoal. Never knew if it was the motors fault or the esc. Motor let out a high pitch squeal right before it smoked. However Hacker said the motor was ok?? Anyways used a 22x12 apce. I'm converting all to the 85-90 amp esc's for the extra head room this year. You'll get around 60-70 amps with this prop depending on batts and which rotor is in the C50.
I was getting 60-62 amps. |
RE: E OTOP
thank you for the infor .I had 2 flight to day 2 min. after landing the motor temps reach 150 degree with 86-89 weather temps !! I think maybe need more air flow to the motor. well!! I will working on the air ducting to night..! let see how it work tomorow , prop 21x13w tp 5300-s4p takeoff weight 10lb 11oz I will post some photor soon.. T LAM
| All times are GMT -8. The time now is 07:21 PM. |
