Engine For CMPRO LEO 110
1 Attachment(s)
I just got my leo 110 and need some advice pls.[:o]
Here are the specs. Wingspan 1740mm Length 1770mm Weight 4.2~4.4 kg Wing Loading 77~81 dm/2 Airfoil Naca 0012 Wing Area 54.2 dm/2 I have these two spare engine that I can use. Saito 150 (with an inverted slimline smoke pitts style muffler) and OS 120AX (with the standard power box muffler). Which engine should I use for my leo? I don't have a perry pump at the moment. Option 1 (SAITO150 with smoke muffler): Shifiting the fuel tank forward and putting a smoke tank at the CG and a smoke pump. Option 2 (OS120AX): Get a perry pump, tank CG position, but Power box muffler sticking out. Thanks in advance. |
RE: Engine For CMPRO LEO 110
Why do you want a pattern with smoke? It is supposed to be as light as possible. Put in the Saito with the stock muffler. My 2 cents...
Saito i heavy, use the 120 ax.
1 Attachment(s)
Decided on the 120AX. The smoke was not for this plane actually. I just got for another plane and thought of using it on the leo cause of the extra space I would have. I very new to pattern flying and learning alot form other threads and realised its not a good idea to add more weight. I just got myself a perry pump and now hunting for a header and a tune pipe that would fit the 120AX.
Any idea what a good size prop should I use? |
APC 16X8 is what I use with the stock muffler. Probably a good brake in on the pipe; then move to a 16X10 APC.:)
1 Attachment(s)
Thx randy. I did a search under your postings and learned about the header by mueller for the 120AX. Is that a company, brand or a person who makes this headers? Forgive my lack of knowledge on this. And how do I go about to get these headers? Are there other brands that makes headers for the 120AX as well?
I got a perry pump from a friend but I think its the old version and it looks old and corroded abit. Model VP-30 |
Can any one recomend me a good fuel pump for this setup? OS120AX, CMPRO Leo, Tank at CG point. Using standard Pbox muffler. Distance from tank and engine about 12 inches. Thx
Hello I-Aquatic! You found pump and tuned pipe ?
It is a guy. He custom makes the best header in the world for a good price.
Karl Mueller Custom Headers http://www.rcaerobats.net/Mueller/Mu...tomHeaders.htm |
1 Attachment(s)
ORIGINAL: aau Hello I-Aquatic! You found pump and tuned pipe ? randy109 how do I give the measurements to Karl Mueller? What I mean is how to describe the measurements to him? Do I sketch out the drawings to him? |
send him an email. He already makes some headers for OS120AXs. So he knows what size the exhast is. If he does not make one for the Leo110 yet; he will tell you what measurements he needs.
Randy |
Great Thx for the quick reply!
Cheers! |
| All times are GMT -8. The time now is 08:29 PM. |
