RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Re: Remote Mixture Control (https://www.rcuniverse.com/forum/rc-pattern-flying-101/6547312-re-remote-mixture-control.html)
ROGUE ROVER 10-27-2007 07:54 PM
Does anyone know of a good and reliable remote mixture control linkage? are they available?
susquach 10-29-2007 09:30 PM
RE: Re: Remote Mixture Control
Don't know exactly what you mean by mixture control linkage, but if memory serves, Webra made a mixture control carb. I believe I still have one in my box of old stff....but I never flew the thing so can't say if it worked as well as advertised. Maybe somebody can fill in the details.
majortom-RCU 10-29-2007 10:06 PM
Bob Violett Models used to have a servo-controllable needle valve, if that would help you any. Haven't looked at their web site lately, but you could check it out.
ROGUE ROVER 10-30-2007 01:16 AM
Yes, what i`m looking for is a mechanism which i beleive adapts to the high end mixture control an the carburettor, which can be connected to a servo to give control of the mixture control in flight.
I looked on the BVM site a,d on the central hobbies site but cant find anything.
Anthony-RCU 10-30-2007 07:12 AM
OS used to make such a thing don't see it now on Towers website but they do have an item by Perry that may suit your purpose.
http://www3.towerhobbies.com/cgi-bin...?&I=LXDG65&P=7
AAbdu 10-31-2007 02:21 PM
You are better off asking this question in or searching the jet / ducted fan forum. I had a BVM in flight mixture control and it worked very well. It basically replaces your engines needle valve and allows you to adjust the needle in flight via the transmitter. I know that there is another manufacturer that makes a similar product but I can't for the life of me remember who it was.
Hope this helps.
Anthony
esamart 11-01-2007 03:06 PM
Similar pushrod and servo system as is used with throttle operates just fine. Put short piece of fuel tube to the mixture needle. Drill hole (about 1/4'') to servo arm. Hole size should be slightly less than total diameter what needle plus fuel tube becomes. So loose you can adjust mixture manually when necessary.
