Pull pull setup for elevators
Hello all! I am going to use a pull pull set up on a CA model Epsilon 90 that I am building. It was between this setup and an mk Bellcrank setup but I think I can get more throw using this setup. Does anyone have any pointers? I think the best way to do it would be to put the servo on its side and then run 4 equal lenghts of pull pull cable, but judging by the room in the fuz, that might be hard to do. Does anyone know if it will work with the servo upright and some of the wires crossing?
I appreciate any input anyone has. Thanks for looking! |
RE: Pull pull setup for elevators
To see the pull-pull setup used by Quique at the world championships go here on RCU and look at the picture in post 13: http://www.rcuniverse.com/forum/m_6674422/tm.htm
Quique used pull-pull on both the elevators and the rudder and both servos are mounted in the upright position. |
ORIGINAL: Funtana140 Hello all! I am going to use a pull pull set up on a CA model Epsilon 90 that I am building. It was between this setup and an mk Bellcrank setup but I think I can get more throw using this setup. Does anyone have any pointers? I think the best way to do it would be to put the servo on its side and then run 4 equal lenghts of pull pull cable, but judging by the room in the fuz, that might be hard to do. Does anyone know if it will work with the servo upright and some of the wires crossing? I appreciate any input anyone has. Thanks for looking! I used two servo mounting platforms, one for elevator, the other for rudder. The elevator plate is mouted with screws so I can access the rudder servo. What I would suggest, if you have not built the fuse yet, is to take the plans, draw the servo on them and use a straight edge to draw the path of the cable from the servo to the control horn. Use this information to trim any bulkheads and formers that get in the way. Do this on the side view also so that you can cut the cable exits in the fuse sides before to start gluing stugg up. This is a lot easier than trying to do it once the fuse is built. Quique used pull-pull on both the elevators and the rudder and both servos are mounted in the upright position. |
Running your elevator servo pull-pull on its side , mounted at the lower area of the fuse will give you the necessary room to clear a pull-pull rudder servo and cables that are mounted closer to the top of the fuse . In fact , my Pursuit 120 ( a great Sam Turner design ) , has a narrow fuse and there are no problems. Recommend you invert the rudder servo. Run 6-32 bolts through hard points to extend 1" above elevator surface, top and bottom. Ditto rudder bolts.Drill the hole through the hardpoint with the elevator top facing your drill press base and in the top foam shuck ,if you have one. This technique places the bolt at an angle for the best position over the hinge line. Run your pull- pull cables through the fuse attached to a length of thin solder wire simplifies the connections. It's a great , lightweight and slop free setup .Good luck !
Running your elevator servo pull-pull on its side , mounted at the lower area of the fuse will give you the necessary room to clear a pull-pull rudder servo and cables that are mounted closer to the top of the fuse . In fact , my Pursuit 120 ( a great Sam Turner design ) , has a narrow fuse and there are no problems. Recommend you invert the rudder servo. Run 6-32 bolts through hard points to extend 1" above elevator surface, top and bottom. Ditto rudder bolt.Drill the hole through the hardpoint with the elevator top facing your drill press base and in the top foam shuck ,if you have one. This technique places the bolt at an angle for the best position over the hinge line. Run your pull- pull cables through the fuse attached to a length of thin solder wire simplifies the connections. It's a great , lightweight and slop free setup .Good luck !
but the pull pull sistem , used by quique, worked fine to win the world championship
DESPITE THE OBVIOUS FLYING ABILITIES.....this sistem, won the WC, so it isnt too much " rolling elevators " coupling... i dont know...the plane was equiped with that sistem the world champion wouldnt use it if its not good... IMHO... |
ORIGINAL: xcead but the pull pull sistem , used by quique, worked fine to win the world championship DESPITE THE OBVIOUS FLYING ABILITIES.....this sistem, won the WC, so it isnt too much " rolling elevators " coupling... i dont know...the plane was equiped with that sistem the world champion wouldnt use it if its not good... IMHO... Frank I. gave very good info. I would add that as long as you place the servo output arm in the center of the fuse, both latterally and vertically, it will matter very little whether the servo is upright or sideways. Upright is a simpler set-up but sideways is a very slightly more accurate set-up....but hardly enough difference to notice. MattK |
ORIGINAL: MTK ORIGINAL: xcead but the pull pull sistem , used by quique, worked fine to win the world championship DESPITE THE OBVIOUS FLYING ABILITIES.....this sistem, won the WC, so it isnt too much " rolling elevators " coupling... i dont know...the plane was equiped with that sistem the world champion wouldnt use it if its not good... IMHO... Frank I. gave very good info. I would add that as long as you place the servo output arm in the center of the fuse, both latterally and vertically, it will matter very little whether the servo is upright or sideways. Upright is a simpler set-up but sideways is a very slightly more accurate set-up....but hardly enough difference to notice. MattK MattK |
Thanks guys this is all excellent info. How tight do you normally tighten the wires?
ORIGINAL: Funtana140 Thanks guys this is all excellent info. How tight do you normally tighten the wires? |
ORIGINAL: dreadnaut ORIGINAL: Funtana140 Thanks guys this is all excellent info. How tight do you normally tighten the wires? Ron's technique also involves a servo driver which drives to specific millivolt output, and that would complete the loop of a fairly sophisticated arrangement, but it may not be necessary for your application MattK |
In post #2 there is a link to a picture of QQ's set up. I notice that he uses a wheel/pulley on the rudder servo, but not on the elevator servo. (I assume that it is not the other way around.)
However, the reason that you get a slight rolling coupling with a vertically mounted elevator servo is that you have a sideways movement of the servo arm as this moves away from neutral, thus pulling more on one cable than the other. Would not this be removed if you used a wheel (pulley) on the elevator servo, keeping both cables equally tight? Magne |
ORIGINAL: Magne In post #2 there is a link to a picture of QQ's set up. I notice that he uses a wheel/pulley on the rudder servo, but not on the elevator servo. (I assume that it is not the other way around.) However, the reason that you get a slight rolling coupling with a vertically mounted elevator servo is that you have a sideways movement of the servo arm as this moves away from neutral, thus pulling more on one cable than the other. Would not this be removed if you used a wheel (pulley) on the elevator servo, keeping both cables equally tight? Magne (edit) |
1 Attachment(s)
Hello Funtana 140. Here's my Epsilon 90 with pull-pull elevatos system.
When you mount the sideways elevator servo, be sure not to just glue your mounting structure down to the pipe floor. Floors are notoriously flimsy and will "oil can" as your servo rocks back and forth.
Thanks Delta Fly they are very good pictures. Would you have a picture of your radio installation in the fuselage?
1 Attachment(s)
Thanks Funtana, here are some pictures of my radio installation in the fuselage.
ORIGINAL: DELTA FLY Thanks Funtana, here are some pictures of my radio installation in the fuselage. MattK |
one more thing guys, how do you thread the two pull-pull wires through the single hole in the threaded eye bolt on the elevator servo end? do you bore the hole out a little to accommodate the two wires? i'm using the dubro 4-40 pull pull system and the hold is only wide enough to take one wire trace through it
Actually, I only use one wire to the top elevator horns and one wire for the bottom.
Each wire loops through one side of the elevator servo wheel and has a single crimp an inch or two away from the wheel. Both left and right sides of the up-elevator line go through a single crimp near the wheel. I hope this is clear. |
Thanks for that. The system i'm running is exactly the same as what you are saying but where the two wires come in for each side of the elevator servo horn (two up elevators one side, two down on the other) there is a little bolt with a hole in it that the wire goes through, the bold then goes into a clevis that snaps on to the servo horn allowing for adjustment. I bored the hole out last night with a 1mm drill bit vertically so I didn't weaken the bolt.
Man, I know all you guys understand all of the above but I have read about servo wheels, ackerman setups, small pullys,parallelograms and more than likley a lot more. All I really need to know is the single servo tiller bar elevator setup in a used sig spacewalker II is ok to use ? I do not know if I has a ackerman set up or not . Thanks from someone who really needs to learn about stuff like this. Glenn. |
Sense my last post I have read a lot info on the pull pull systems, the only thing I did not see was anything about mechanical advantage for the servo, on normal systems they tell you to use hole nearest the servo shaft and one out aways on the control horn for better leverage for the servo. I guess this is not needed when using high torque servos? Guess i will stop before I look like a total idiot, to late,right? Thanks, Glenn. |
The only dumb question is the one not asked, eh Glenn?
However you set things up, you'd like to maximize the travel distance for your cable or pushrod. That way you minimize slop. (Imagine 1mm of linkage slop in a quarter inch of throw versus the same slop in two inches of throw.) So you'd like to maximize the throw out of your servo wheel. I use the biggest wheel that comes with my servos, cut it into a 'D' shape, and cable to the outermost holes. On the elevator control surface you will want at least as much distance between the horn holes as you have between the servo wheel holes....if not more. Keep in mind that you have plus and minus forty-five degrees of throw out of your servo and if the holes are the same at the elevator, that's the throw you'll have there. So here's where you can get some mechanical advantage. You really only need maybe 25 degrees max elevator throw for most pattern flying. So you might lengthen your elevator horns to get that with your servo output throw. If you stay with the 45 degrees of throw you will probably need to reduce it electronically which will give up some resolution. That's where servo quality, e.g. torque and resolution become factors. |
Nice description Ron.
Easy to understand. Orlando |
Ron:
What cable brand or set=up do you use. I have been using I believe is the "Sullivan" brand which has some kind of sheating over the cable' it has not frayed in many years of use. I was wondering if the "Tettra" pull-pull system is any better. Although with the longevity I have had with the one I have used it may be a mute point. I do however set uop my pull pul the same way you do. Woprks great. Orlando |
Thanks for your help guys. Glenn. |
ORIGINAL: crashlander Ron: What cable brand or set=up do you use. I have been using I believe is the "Sullivan" brand which has some kind of sheating over the cable' it has not frayed in many years of use. I was wondering if the "Tettra" pull-pull system is any better. Although with the longevity I have had with the one I have used it may be a mute point. I do however set uop my pull pul the same way you do. Woprks great. Orlando Lately I've been using Surflon 60 test 1x7 fishing leader. I think I got it from Wal Mart. It's also plastic coated. If you don't want the coating you might consider u-control line. -Ron |
| All times are GMT -8. The time now is 03:16 AM. |
