electric pattern?
stopped at the bar for 2 drinks after work and a woman told me that Jason might fly an electric pattern plane at the worlds? could this be true?
electric pattern?
I heard that he is flying Angel Shadows again this year as he has ordered 2 new ones from Russia. also since he flew one at the team trials, I wouldn't think that he would change models this late before the worlds.
electric pattern?
Plus I'd say this wouldn't be too good for his engine sponser, OS.
(He is still with them isn't he?) |
electric pattern?
Robert, why would he need an OS sponsorship, If he has an electric motor companys sponsorship?
I think I saw somewhere, Jason was comenting on his experiences (peformance wise) with the 3M 170. Can't remember the page, but I pretty certain it was a US based page, that had a comparison of engines RPM wise. Anyhow, should be interesting to see if he has gone electric, It definantly seems to be the future of pattern flying. |
Electric patttern plane
At the SEFF show Jason said that he would fly an electric plane at the Worlds if it was ready. It is currently being built
electric pattern?
Can they just change sponsers like that? Well I suppose with Chip and PL its possible. My bad.
Akro 2
The current issue of Quiet Flyer has a picture of Jason with an electric powered pattern plane called an Akro 2. It is powered by Thunderpower lithium polymer cells and a Hacker brushless motor. The weight is reported at 9.5 lbs. Maybe this is the plane you have heard of?
Akro 2
The Akro 2 was flown by Jason at the SEFF show in June. The model was a prototype from Aero-models. Don't know if this is Jason's plane or if it will be a different model.
electric pattern?
the acro is a lorenz plane, dunno if they make it anymore, can't find it on the site. 3 of their "rhapsody" planes were just picked up for Jason at the worlds. If things work out, he'll be flying them with Hacker C50 acro motors and thunder power lithium cells. the rhapsody's are "current" style planes for pattern and/or 3D (they have a specific 3D version but that's not what he got). With the lithiums and the C50 acro's, power is somewhere between 140 and 170 glow, total weight should be just under 10 lbs (they're a touch lighter than the acro-2's) and flight time is close to 1/2 hour per charge. i think the website witht he rhapsody's is www.f3alorenz.de
electric pattern?
Wow that should be quite a setup!!!!!!!!!!!!
What is the average weight of a WC level plane all fueled up? What is a lithium battery pack such as that worth? Lifespan? |
electric pattern?
I still believe this is the way F3A is going to go.
All this belly-aching and talk of Gas power is just a cover up for the electrics. Now you won't even have to buy Gas. I don't think I want to know how much that set-up is going to be worth including all you special chargers for those type of cells. |
electric pattern?
Originally posted by Cdallas2 I still believe this is the way F3A is going to go. All this belly-aching and talk of Gas power is just a cover up for the electrics. Now you won't even have to buy Gas. I don't think I want to know how much that set-up is going to be worth including all you special chargers for those type of cells. |
Funny thing about batteries...
The funny thing is that, they might be a bit pricy, especially the big ThunderPower LiPo packs needed for F3A (around $400-$600 depending on final configuration), but the cost to "refuel" them is oh so CHEEP. ;)
Compare the battery/motor cost to a YS DZ140 (and dozens and dozens of gallons of fuel) and it doesn't look so bad. I saw Jason fly the Acro 2 at SEFF. It wasn't underpowered at ALL by anyone's reckoning. In fact, a lot of folks just stared, slack-jawed, in amazement. Rick. |
electric pattern?
I have no experience with anything other than NiCads at the moment, so bare with me if these are stupid questions.
How many cycles does the ThunderPower LiPo pack last for? Do the LiPo batterys get a memory, or reduced capacity as they get older? What sort of charger is used to charge and monitor the packs condition? What is the throttle response like in this setup? Is motor and or battery cooling a problem? Db readings? Thankyou, Cameron McDonald |
electric pattern?
How many cycles does the ThunderPower LiPo pack last for? Do the LiPo batterys get a memory, or reduced capacity as they get older? What sort of charger is used to charge and monitor the packs condition? What is the throttle response like in this setup? Is motor and or battery cooling a problem? |
electric pattern?
lipo packs don't tend to get hot like nimh/nicad, so battery cooling isn't a big factor in designing the aircraft. Motor cooling, however, is another story. Motors that never got hot with 8 to 10 minute flights tend to get rather "tasty" with 30 minute flights, so more motor cooling should be planned for, or, more efficient motors like the hacker C50's. Talked with Sean this morning (importer of hacker motors). They've flown the rhapsody's and performance is good, but they are a couple ounces over the weight limit. Currently have large rx packs and big servos everywhere, so that little "problem" will be recitifed shortly. The 10-cell lipo setup is working well, spinning a 20X13 prop in the mid 6K range. The only negative is that speed is a bit high, so they might actually have to prop down and reduce power a bit :) .
electric pattern?
Gary - I saw you had the E3DXL at SEFF. I remember reading how you wanted to do an electric pattern plane after you lost your Lexx. Have you looked into that anymore?
electric pattern?
How many LiPo packs would you need to fly 6 flights/day? How long would it take to charge a LiPo pack large enough for F3A flying?
Electric pattern plane video
I believe this is avideo of the plane in question.http://www.rccraze.com/newpattern.mpg
electric pattern?
Would take a lot, but you have to classify exactly what a single flight is. With glow, you're looking at 9 to 10 minutes, whereas witht he li poly's you get about 1/2 hour flight time with an electric,..i.e. 3 times a glow. It takes a bit over an hour to charge. You charge constant current at 1C rate till you reach 4.2V per cell, then hold that voltage and start dropping current till current reaches zero. They reach 4.2V per cell in about 45~50 minutes and they're about 95% charged at that point. It takes another 1/2 hour to 45 minutes with the current tapering off to get the other 5% in. I generally fly when they reach 4.2V per cell. I figure I'm not going to fly 1/2 hour continuously, but more like 10~12 minutes like anyone else (I've actually sat at our field on sundays and timed people, other than the few exceptions, average flight time is 8 minutes with the glow guys and we have a very large club, 30~40 guys there on a sunday, so it's a good representation). li-poly charge times are lengthy, but what I've found is that I normally fly a 10~12 minute flight, sometimes extending that to 15 minutes (timer start at takeoff roll and stop on wheels down). I can plug in to the charger and "top off" the pack in 30 minutes, but fly whenever I really want to cause there's another 15 minutes or so worth of time in the pack after I land,..i.e. I don't really have to wait on charge to finish. li poly's are different from nicad or nimh. There is no memory, and they actually prefer to be charged to 90~95 percent, then discharged partially (not all the way down, can't go below 2.5V per cell or damage occurrs), so they actually suit the normal style of flying far better than nicad/nimh. They can also be charged, and sit for literally weeks before flown, with no noticable degredation in performance,..i.e., they don't have to be flown "hot" off the charger. I fly quite a few 10-cell planes (or 3series/4 parallel 8200 thunder power lipo's,.. they're same size as 40-size glow planes), and I keep 3 pakcs charged. If I want to go fly after work for instance, I always have 3 packs ready (hour and a half of flight time, about 7 to 9 equiv. glow flights). sometimes I don't even take a charger to the field since I have plenty of flight time available with those packs. for F3A, you would use 9S4P, or 10S4P (10 series, 4 parallel is what's in the rhapsodies for Jason), so that would be 30 minutes of flight time roughly,.. available without charging, or 3 practice patterns per charge.Since the normal routine at the field is to fly, then BS with the guys 15~20 minutes,..then repeat, you can actually charge during the normal downtimes and fly as much, or more, than glow. Sorry for the long dissertaion,..but with the long flights now available with electric compared to glow, you can't really compare in number of flights flown since electric flight time is about 3 times glow flight time per charge/fueling.
Originally posted by MPX_4000 How many LiPo packs would you need to fly 6 flights/day? How long would it take to charge a LiPo pack large enough for F3A flying? |
electric pattern?
in this configuration being discussed is there a separate "flight pack" for the servos and Rx? or does it run through a BEC like the little-er ones do? sorry, my experience with electric is only with the little parkfliers
thanks Hubb |
electric pattern?
You can do it either way. They're using a small reciever pack in Jason's planes. The only BEC option is with an ultimate BEC (U-BEC by www.koolflightsystems.com). The U-BEC, however, is rated for 5 amps, and so with a "normal" pattern setup (digital servos everywhere) you'd be above that, so a seperate small reciever battery is really the way to go to not risk anything. BEC's are reliable, I use the U-BEC's in most everything, but there is no BEC option for setups drawing lots of current (several digital servos). I'm using a U-BEC even in my 88" span 3D electric (some videos in this report http://www.rcgroups.com/articles/ezo.../seff/seff.htm), but it has 5 non-digital servos in it.
electric pattern?
Gwright,
Thank you for the long response (appreciated). I guess I am a little different than most I have my timer set for 18 minutes (start just before takeoff) and can fly in the low 20 minutes. I usually fly an F3A routine, take a mental break and work on a few maneuvers, then fly the routine again, so 30 minutes available is not too different than my current setup (I probably have about 23 minutes if I fly the tank empty). I also try to practice 5-6 flights per day. Since the batteries can be charged in 1 hour, then I believe I would plan to have about 3 packs, flying and charging continuously to always have a pack available. How long should I wait before charging a pack that just finished flying? How about the motor, how long should you wait between flights to let the motor cool if I were to fly 20 minutes per flight? Electric pattern sounds very interesting! I know Dave Von Linsowe tried it a few years ago with a USA Star, but the battery technology and probably the motor technology may now make it a much more viable option. |
electric pattern?
Gary,
How many Lipo chargers do you use to keep your hangar of electric planes (the ones you fly on a regular basis) ready to go? Wiz |
electric pattern?
electric flight....it is manifest destiny!
Truly, though, LiPo's are changing everything. |
electric pattern?
I mainly use an orbit-pro for the li polies, but I do have a triton (not extremely usefull since it only goes to 2.5 amps), a couple supernova's (nicad/nimh) and a schulze 636 (only .5A rate on lipos, so used for nicad/nimh).
electric pattern?
What is a setup like this going to cost?
And then how much for chargers and cyclers? |
LiPo for F3A
Like a well-to-do cousin of mine once told me when I asked what his pair of brand new his-n-hers Mercedes sports cars cost, "if you have to ask, then you probably can't afford it!". :D
A TP 5S4P LiPo pack goes for $325 (2 of these used in the mentioned Rhapsody), around $1300 USD for the Rhapsody airframe, $210 for Hacker controller, ~$310 for the Hacker motor, add radio, hardware, accessiories, Orbit charger for around $299...it does add up doesn't it? Rick |
electric pattern?
$750 for the battery pack of a single plane is getting a bit steep. I wonder how many people spend $750 on glow fuel in a season?......I wonder how many seasons a Lipo pack will last for?......I wonder how many pilots would feel comfortable competing with any less than two of them in their possession?
I believe the Y.S. 1.40 DZ cost about the same as the Hacker motor and controller. Most serious pattern pilots would want to have two of these in this their possession.....I would think. I have an Orbit Pro now and I don't fly electric pattern. Although, I do fly NiCd and NiMh electric planes and the Orbit charges those batteries very well. I think of the charger as a support item for many planes.....radios....cordless tools and other toys. It will last for a very long time, so its cost can easily be justified in my mind. The rest of the plane....airframe, servos and such is the same as its glow powered equivalent. So, is flying electric powered pattern more costly than glow powered pattern? If you are comparing similar sized planes and you take into consideration fuel cost, I would say the electric is still (probably) more expensive......But then you gain electric power dependability, cleanliness and quietness. Are these attributes worth the extra expense? That's up to the individual. I thought those attributes were worth the extra expense on my sport planes. That's why for the past year I've been phasing out the glow powered planes in my hangar. I'm down to two planes and three engines. By the end of the season they'll all be gone. Wiz |
electric pattern?
thats for the individual to decide, depends on how much they fly. When I was "trying" to compete in F3C, I know my personal record of practice in a month was 62 gallons of fuel. 30% CP was running in the $25 to $27/gallon range at that time, so that was over $1500 in fuel that month. That's right at 500 flights which should be about 1/2 the usefull life of the lipo packs. Even if abused, they should go 500 flights, so that puts the cost down to about 1/2 what glow is, and as you stated, powerplant costs, airframe costs, yada yada, are the same, so it would be less expensive with electric. However, I think that example at the far "end of the curve" so to speak,.. not many fly that much in an entire year. Your question about how much people spend in glow fuel,... well,.. if you fly 10 flights per week (assuming 16 oz tank) with the CP30 or something similar,.. you burn that amount in a year (520 flights, i.e. 52 weeks in a year).
[QUOTE]Originally posted by Mike Wiz [B]$750 for the battery pack of a single plane is getting a bit steep. I wonder how many people spend $750 on glow fuel in a season?......I wonder how many seasons a Lipo pack will last for?......I wonder how many pilots would feel comfortable competing with any less than two of them in their possession? |
electric pattern?
The advantages to electric power FAR outweight glow to me..
1) no mess. There is nothing to clean. 2) no vibration. Airframes can be built lighter and will not wear out. 3) perfect power. Assuming the power is available, the power is always there. No lean runs, no sucking a e-clip into the intake.. etc. Electronic components can burn out of course.. but the idea is very intriguing for sure. 4) quiet. I believe this is going to be more pressing of an issue in the next 5 years. Much moreso than people think. I'm going to take the plunge and build an airplane specifically for F3A using E-power. It'll likely be an off the shelf design built as light as possible. With the LiPo's I basically need a 6.5 pound airplane minus power system. I think that's very doable. |
electric pattern?
Just to agree with Doug and emphasize a point about no vibration.
Think about that term- "no vibration". How many of us have had to replace servo gears (or whole servos), output arms, clevises and fittings, engine mounts, and even entire airframes, due to just VIBRATION damage? This in itself, potentially saves hundreds of $$ in a year. Add to that...the advantages of not having to fiddle with flameouts, needle valve settings, lean/rich runs, exotic/temperamental pipes, pinholes or other leaks in the fuel system, fuel pump/regulator tuning, toasted crankshaft bearings every 50-100 flights, burned out plugs, etc (the list is endless), certainly helps to mitigate the added cost of an electric installation. The power is THERE, INSTANT, and CONSISTENT. E-power for pattern? Costly, yes. But it will certainly save money in the long run and pay many dividends in many areas. Something to think about. Rick |
electric pattern?
Since there is no vibration couldn't the airframe be built even lighter?
And with all technology the longer you wait the lower the price becomes. After a few years these LiPo may come down to a price the rest of us can afford. |
electric pattern?
Airframes can be built lighter for sure. Problem is they still need the stiffness. So long as you remember stiffness does not mean heavy, you'll be fine.
And yeah.. the LiPo's will come down.. and I think we're right before a MAJOR breakthrough in battery technology that's going to open the door in a hurry. |
electric pattern?
And yeah.. the LiPo's will come down.. and I think we're right before a MAJOR breakthrough in battery technology that's going to open the door in a hurry. Wiz |
electric pattern?
It's just a hunch really, but this is where the majority of research money is going right now.. Motors are understood things and power is just not an issue there.. it's the batteries to drive the motors that are the problem.
Just my opinion.. |
electric pattern?
Free market competition alone will drive down the cost of LiPo's. That's already happening to a degree as various vendors compete for our LiPo dollars. Of course, any new technology is improved on with time. In 2 or 3 years, it's not too far out to say we may well have LiPo technology with twice or 3x the present energy density, half the weight, and half the cost. Look at how far computers have come in just 5 years.
Advanced cutting-edge technology is just cool like that. :) Rick |
electric pattern?
For F3A, for electric power plants, does the weight of the plane to meet the 5 kg rule include the batteries (fuel)? I think that is the case, but does give some advantage to glow fuel planes that are weighed empty.
I do think the power from an electric motor could be superior to glow engines due to reduced vibration, low speed torque, quiet operation, no oil residue, consistency, low idle (zero if you want), no CG or weight change throughout the flight, and I am sure there are more. I would want to have sufficient power reserves available that I would not have to think about energy management during a flight. |
electric pattern?
I have read that Jason Schulman's Rhapsody will come in just under the limit once some minor equipment changes are made. But that does pose an interesting question: What ought the FAI/AMA rules be about the max empty weight of IC planes vs. electric? Can an argument be made that the battery is a "fuel tank", or is it the fuel itself? I haven't looked at the FAI rules lately concerning it, but it might come to a head as more folks enter FAI classes with electrics and challenge the rules.
My own position (FWIW), is that IC powered craft should weigh within the 11 lb limit fully fueled, since the LiPo battery's weight doesn't change with "fuel load", and that would be a significant disadvantage to electric guys. Anyone know what FAI/AMA says in the rulebook about this now? Rick |
electric pattern?
This might mean that the big engine manufacturers like YS and OS will have to drop there prices???? What do you all think?
| All times are GMT -8. The time now is 05:45 AM. |
