RCU Forums
-   RC Pattern Flying (https://www.rcuniverse.com/forum/rc-pattern-flying-101/)
-   -   Construction of a 2x2 pattern plane: the ANTI-GRAVITON (https://www.rcuniverse.com/forum/rc-pattern-flying-101/9749764-construction-2x2-pattern-plane-anti-graviton.html)
geoffroyBelgium 05-21-2010 02:22 PM
The first time I have seen a picture of the voodoo express designed by Nat Penton, it was almost like an illumination. Indeed, I was trying to find by myself a new design for a pattern plane governed only by the performances (not by the look). Then, I realized that Nat has already imagined this plane many years ago. Moreover, I think that this design is perfect for an electric pattern plane since it can be easily builded very light. Therefore, after the end of the construction of a more classical pattern plane (the Graviton http://www.rcuniverse.com/forum/m_90...tm.htm#9040604), I decided to start the construction of a second 2m pattern plane strongly inspired by the design of Nat's Voodoo express: the anti-graviton.
Construction of the Wing
The rib are made of 6 mm depron. I'm using a technique derived from the "laser method". Pieces of depron are placed to form a comb. Afterward, the ribs are cut with a CNC hot wire. This method is very nice because (i) the ribs are cut very precisely and (ii) the remaining part will form a support for the assembly and for the sheeting.
http://www.lumay.be/imagesForums/ant...RibCutting.jpg
The first rib and the one situated at the extremity of the sheath are reenforced with 100g/m2 glass fabric and epoxy.
http://www.lumay.be/imagesForums/ant...einforcing.jpg
After the cutting, the ribs and the longerons are glued with alyphatic glue.
http://www.lumay.be/imagesForums/ant...reSheeting.jpg
The sheeting is made with 1.5mm balsa. On the next picture, the sheets of balsa are sanded to obtain straight borders, assembled with tape and glued with alyphatic glue.
http://www.lumay.be/imagesForums/ant...reparation.jpg
Stab construction
The stab and the rudder are made with foam sheeted with 1.5mm balsa. The two servos for the stab are placed inside the stab.
http://www.lumay.be/imagesForums/ant...oamCutting.jpg
http://www.lumay.be/imagesForums/ant...bLEGlueing.jpg
http://www.lumay.be/imagesForums/ant...bLECutting.jpg
http://www.lumay.be/imagesForums/ant...tabSanding.jpg
Rudder construction
http://www.lumay.be/imagesForums/ant...ton/rudder.jpg
If you are interested by this construction, I will continue to post some pictures and some explanations.
apereira 05-21-2010 03:14 PM
RE: Construction of a 2x2 pattern plane: the ANTI-GRAVITON
Good luck with your new project!
All construction design and construction threads are welcome for most of us, it's nice to see a pattern plane built from the ground up. Very interesting the depron ribs, do you have a weight savings in comparison to balsa? or it's just easier to cut them with CNC?
regards
geoffroyBelgium 05-22-2010 04:11 AM
I do not realy save a lot of weight by choosing 6mm Depron rib instead of balsa. It will be possible to save weight with 3mm depron. However, Depron is very easy to cut and very cheap if we compare with balsa. In addition, I don't know if it's the same all over the world but in Belgium, it becomes very difficult to buy good quality Balsa. Then, when it's possible, I replace the balsa by alternative solutions.
guille2006 05-23-2010 03:31 AM
Keep posting...
I'm really saving weigth by making the ribs as a sandwich on Rohacell foam and two carbon fiber layers... comes 1/3 of the weigth of balsa.
geoffroyBelgium 05-23-2010 06:07 AM
Then, I continue to post some pictures
The stab, the rudder and the small vertical wings are finished!
http://www.lumay.be/imagesForums/ant...derWinglet.jpg
The longerons of the wing are reinforced with carbon, epoxy and a thin hard wood.
http://www.lumay.be/imagesForums/ant...inforcment.jpg
The trailing edges are also reinforced
http://www.lumay.be/imagesForums/ant...ailingEdge.jpg
Now it's time to start the construction of the fuse!
The motor, the controller and the Lipos come from china. I know that the small turnigy motors are very good if consider the price. I will test this big one.
http://www.lumay.be/imagesForums/ant...oriesMotor.jpg
http://www.lumay.be/imagesForums/ant...soriesLipo.jpg
The fuse will be constructed from 6mm depron formers.
http://www.lumay.be/imagesForums/ant...useFormers.jpg
geoffroyBelgium 05-31-2010 10:47 AM
The fuse sides are made with 4mm balsa partially covered by 160g/m2 carbon fabric + epoxy. A glass plate is waxed and coated vith PVA. The two pieces of carbon fabric are imbibed with epoxy and are placed on the plate. Then, the balsa is compressed on the fabric during the epoxy curing.
http://www.lumay.be/imagesForums/ant...arbonPlate.jpg
http://www.lumay.be/imagesForums/ant...SideCarbon.jpg
http://www.lumay.be/imagesForums/ant...arbonBalsa.jpg
http://www.lumay.be/imagesForums/ant...arbonPress.jpg
http://www.lumay.be/imagesForums/ant...rbonBalsa2.jpg
The holes are made with my new CNC mill.
http://www.lumay.be/imagesForums/ant...lsaMilling.jpg
http://www.lumay.be/imagesForums/ant...alsaMilled.jpg
The work on the wings is also going on.
http://www.lumay.be/imagesForums/ant...neSheeting.jpg
http://www.lumay.be/imagesForums/ant...etingPress.jpg
geoffroyBelgium 06-03-2010 03:20 PM
The construction of the fuse evolves slowly
http://www.lumay.be/imagesForums/ant...rsAndSides.jpg
Any remarks about this construction? :(
Diver09 06-04-2010 01:16 PM
Looks awesome! Keep up the good work. I might be making a smaller version that accepts a single 5 cell 5000 lipo. I scratch built a plane similar to this last year and it is very rewarding in the end. Although it takes forever the end result will be very worth it!
-Chris
dreadnaut 06-04-2010 06:38 PM
ORIGINAL: geoffroyBelgium
Very interesting, and good work. One thing I have noticed is that when making flat panels, as you are doing here, the PVA is not always needed if you are laying up an a really smooth surface. I have not tried glass, but have done this with 3mil mylar sheet stretched over a smooth surface, and it does not even need waxing. The mylar sheet peels right off.
geoffroyBelgium 06-05-2010 09:38 AM
Yes it's not necessary to use PVA in addition to the wax. It was just a security because I'm scared to have my stuff stuck on the mold. To have a perfect surface quality, it's even better to avoid the PVA.
More pictures soon...
geoffroyBelgium 06-21-2010 02:27 PM
The work is going on slowly.
http://www.lumay.be/imagesForums/ant...foreCover1.jpg
http://www.lumay.be/imagesForums/ant...foreCover2.jpg
http://www.lumay.be/imagesForums/ant...foreCover3.jpg
http://www.lumay.be/imagesForums/ant...foreCover4.jpg
Still a lot of work...
Bundubasher 06-21-2010 02:56 PM
Geoffrroy, very nice thread, keep posting. I like your foam cutter, is it hand built?
Bundu
geoffroyBelgium 06-21-2010 03:04 PM
Thanks. I need some motivation to finish the work now...
Yes the foam cutter is a selfmade one. Here are some pictures:
http://www.lumay.be/aeronautics/CNCf...audCNC0000.jpg
http://www.lumay.be/aeronautics/CNCf...audCNC0004.jpghttp://www.lumay.be/aeronautics/CNCf...audCNC0003.jpg
http://www.lumay.be/aeronautics/CNCf...audCNC0001.jpghttp://www.lumay.be/aeronautics/CNCf...audCNC0002.jpg
http://www.lumay.be/aeronautics/CNCf...s/DSCN3226.jpg
Bundubasher 06-21-2010 03:23 PM
Very nice indeed, need motivation?, look at the pics of that plane and get on with it and finish it .......post a pic when it is "alles klaar".
Cheers
Bundu
geoffroyBelgium 06-28-2010 03:35 PM
I'm approaching slowly the end of the construction. But still a lot of work to do...
http://www.lumay.be/imagesForums/ant...CanopyOpen.jpg
http://www.lumay.be/imagesForums/ant...oAndCanopy.jpg
http://www.lumay.be/imagesForums/ant...ingCovered.jpg
geoffroyBelgium 07-11-2010 07:41 AM
We are close to the first fly!
http://www.lumay.be/imagesForums/ant.../finished1.jpg
I can post more pictures if you are interested
geoffroyBelgium 09-12-2010 05:58 AM
After a crash due to a radio problem (probably induced by the carbon inside the fuse...), I replaced the turnigy motor and controller by an AXI 5325/18, a Jeti SPIN 99 opto controller and an APC E 19 x 12. I keep the lipo turnigy 20C 8S 5000 mAh. I have really more power and the weight of the plane is now only 4.6 kg ready to fly.
I'm really happy. The flying characteristics are awesome.
http://www.lumay.be/imagesForums/ant...tonRepare1.jpg
http://www.lumay.be/imagesForums/ant...tonRepare2.jpg
http://www.lumay.be/imagesForums/ant...tonRepare3.jpg
Someone have some news about Nat Penton?
Thanks to www.insightrc.com for the informations about the voodoo express.
flyintexan 09-12-2010 03:28 PM
Geoff,
Congratulations. Very nice construction work!
Best Regards,
Mark
guille2006 09-12-2010 04:46 PM
Nice job, Do we have any video to share?
Cheers
Guille
swlarcham 09-13-2010 12:12 AM
Geoff,
You asked about Nat Penton.
I live in the same city as Nat and consider him my mentor.
He is Not flying currently.
His wife passed away last year after a rather lengthy illness and it took quite a toll on him both mentally and physically. He just hasn't gotten encouraged to get back to flying since then. I keep hoping he will.
I enjoy every visit with him. He did come out to a couple of pattern meets this year here in D-6(USA) to visit and everyone enjoyed seeing him.
I'll tell him you asked about him.
Eddie
geoffroyBelgium 09-16-2010 12:23 PM
Thanks Mark. I'm happy to obtain some congratulations from you.
Guille, I'm not a video specialist. But if I have the opportunity to make a good video, I will share it here.
Eddie, if you have the chance to see Nat, do not hesitate to tell him that a guy in Belgium has build a F3A plane strongly inspired by the Voodoo and that I'm very happy about this plane.
swlarcham 09-16-2010 07:14 PM
Already have as I knew he'd get a kick out of it.
He enjoyed looking at your construction photos.
I'll have to give him an update to let him know you've flown it and are happy.
I've enjoyed your thread also.
Eddie
