battery discharge
AR
battery discharge
Does a transmitter battery discharge faster when in use (constantly moving the sticks) than when just sitting with the switch on? In other words, can I time the time it takes to go from full charge to 9.4 volts simply by turning the transmitter on or would that give me a false reading from what it would be if I were flying?
Banned
RE: battery discharge
ORIGINAL: DMcQuinn
The battery usage will be the same.
I just wonder if you ever checked that and know it by personal experience.
Zor
My Feedback: (13)
I must admit that I have never checked this with an ammeter. But I am a bit of an electronic expert (amateur radio - "ham" - extra level). The transmitter uses most of the battery to drive the power out of the antenna. Moving the sticks drives a potentiometer which changes the pulse width of the pulses sent by the transmitter. But the energy required is the same no matter what the pulse widths.
Banned
ORIGINAL: DMcQuinn
I agre with you.
Nice meeting you in this forum.
Best wishes to you and yours for the New Year.
Good flying and many QSOs.
73 from licensed VE3??? also licensed VA3?? .
Still active on 80, 40 and 20 meters.
Dah di dah.
