85MG Micro Servo horn screw size
What is the size of the screw that keeps the servo horn in place. Lost mine on a brand new servo?????? 85 MG hitec. Thanks
VA
RE: 85MG Micro Servo horn screw size
ORIGINAL: Hoosier06
What is the servo bolt size for the 85 MG Hitec servo?? Lost one on a brand new servo. Thanks
Twelve for $0.25. It does not mention the size, but I'm pretty sure it's 2.3 mm or something similar.
NY
You can find just about every detail of a Hitec servo at www.servocity.com along with parts and prices
ORIGINAL: Hoosier06 What is the size of the screw that keeps the servo horn in place. Lost mine on a brand new servo?????? 85 MG hitec. Thanks
"2.3 x 5 mm Phillip-head (JIS) screws x 5, fit the HS-65MG, HS-81MG, HS-85MG, HS-125MG.
NB: Never use red loctite, in need if star washer is lost, Liquid Thread Lock
used sparingly and ensure none remains in contact with plastic parts."
Alan T.
Alan's Hobby, Model & RC FAQ Web Links
(quick search = Ctrl+F)</dt>
My Feedback: (41)
ORIGINAL: BuschBarber
If you go to MicroFasteners.com, you can get Socket Head Servo Screws. I like them for MG servos because if you use Threadlock on the screws, it is easier to remove the screws without stripping the Phillips Head.
