Unwanted differential DX6i
I have different throws on UP & Down ELEV ch. Subtrim set to 0. Expo 0.
I have this problem on 2 different planes, which leads me to believe it is in the TX not the servo. I haven't found a differential setup in the menu tho... can anyone help?
V.
V.
Banned
RE: Unwanted differential DX6i
ORIGINAL: vasek
V.
V.
Did you look at travel limits ?
Zor
ORIGINAL: vasek
V.
V.
ORIGINAL: vasek
V.
V.
Throws are set at 100%, just one servo for the elevator.
I can see the servo arm not moving enough in one direction, as if there was a differential dialed in.
I don't think there is a DIFFERENTIAL function on Dx6i, is there?
never mind, found it!
i had a 50% in travel adjust for the down elevator, don't know why[]
everything is dandy now, thanks guys for the help!
V.
V.
