Futaba 2.4 ghz receiver question
1 Post
RE: Futaba 2.4 ghz receiver question
FASST and FHSS or S-FHSS receivers require a radio that is able to transmit in both modes. The 10CAG only transmits in FASST 7Ch and FASST Multi.
The compatible receivers are found here under the FASST column
http://www.futabarc.com/receivers/air.html
also look further down the page for a table shoing which are compatible Rx's.
You cannot use a FHSS or S-FHSS Rx with a 10CAG.
Currently only the T6J can use the FHSS/S-FHSS Rx's. The 18MZ will also be compatible with these when it is released. Thereafter the T8FG(S), T12FG, T12Z, T14MZ will also receive a software update to enable use of the FHSS/S-FHSS Rx's. Your 10CAG will not be upgradable
