Dual rcvrs
Dual rcvrs
I a question about running dual receivers with a 2.4ghz radio... is it possible? I'm looking at converting my JR radio to 2.4 and I have a P-82 that I run dual receivers in. I want to keep the same setup. Any info would be appreciated.
RE: Dual rcvrs
ORIGINAL: shakey44 I a question about running dual receivers with a 2.4ghz radio... is it possible? I'm looking at converting my JR radio to 2.4 and I have a P-82 that I run dual receivers in. I want to keep the same setup. Any info would be appreciated. Thanks
Dual receivers are very populay with large scale as in need, user can bring a bird home on"one side" using one aileron and opposite elevator per receiver.Throttle on one receiver and the throttle cut-off on the other.SWB makes a Self Adjusting Servo Tray W/ Bellcrank so two rudder servos can work independently.
Optima Transceiver (RX) - Dual Redundant receivers -
The first turned on after the Transmitter will be the recognised telemetry sender.
Optima Transceiver (RX) - Dual or Multiple Batteries may be installed - Avoid Brownout
& Add Redundancy, even one for each servo.
more under sub section "Giant Scale, Large RC models, Twins & Multi Engines" e.g.
. Dual Receivers -
. Dual Receivers #2
. Dual Receivers #3 at
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
Alan T.
RE: Dual rcvrs
ORIGINAL: shakey44
