new to this stuff, receiver ?
Will the old futaba Conquest FP-T4NL AM radio with the FP-R4F reciever run a brushless motor?Can i plug the ESC into this receiver?
RE: new to this stuff, receiver ?
The old fp-r4f is AM and on the old (now illegal) 72/75 Mhz band or 27 Mhz:
http://manuals.hobbico.com/fut/3fn-4...6fn-manual.pdf
Only the esc plug into the Rx and drive the motor so it doesn't matter what type of motor(brushed/brushless)is used as long as the esc is appropriate. These older Futaba receivers used "G" connectors rather than "J" type so you'll need those for servos and esc!. The center pulse in olders Futaba is also 1.32ms instead of 1.5ms but that should only affect neutral position with modern servos(older Futaba servos with "G" plug will center normally).
Then there is that Rx: MCR-4A sold with FP-4NBL which had a built-in brushed esc(page #4):
http://manuals.hobbico.com/fut/4nbl-manual.pdf
This one is more recent than the one first linked to and while being AM uses post-1991 frequency. The brushed esc is good for up to 8.4V batt. and the Amp draw of a "500" size brushed motor maximum(30 A max). That Rx cannot be used with an external esc for brushless use.
ORIGINAL: jayseas
EXPLAIN ABOUT ILLEGAL?pLEASE
ORIGINAL: jayseas
Rich, what problems are caused by using this radio?
Given the cheap cost of some of the newer, cheaper 5 channel 2.4Ghz radios, you would probably be better off buying a 2.4 system. With 2.4, you do not need Frequency Pins, there is much less chance of being interfered with by RF noise, and you don't have to worry about anyone shooting you down or you shooting down anyone else.
