Digital servo on retract air valve
Hey guys,
Did I read somewhere that using a digital servo to operate a retract control valve is a no no and one should use analog servos instead. Or maybe it was using a digital servo for mechanical retracts?
I'm thinking it had something to do with the way digitals resolve the signal and the way they will try so hard to center etc. that they don't deal well with the on/off positioning required for retract extremes (ie. valve on/off or mechanical wheels up/down). Therefore they draw down the battery needlessly.
Old story...bad info...losing my mind?
Not that big of a deal, but I'm about to order a mini servo for the retract valve so I'm wondering....digital or analog.
Thoughts if you have a minute would be great...
Tom
Tom
My Feedback: (10)
RE: Digital servo on retract air valve
I think your thinking about Mechanical retracts that use special Analog Retract Servos, I don't believe it matters on a retract valve; its a matter of setting your end points, centering in not an issue.
Oh good so I have my mind for another day!
I'll move forward on that basis and get the small digital and as I think about it more, you are right, centering is not the issue.
Appreciate your taking the time to chime in!
Tom
Tom
ORIGINAL: dasintex
ORIGINAL: BuschBarber
Retract servos are traditionally 180deg servos and not Proportional. I understand that there is a Spektrum Retract servo that is proportional and thus capable of setting End Points. I am told that Digital Servos are not appropriate for Flaps. I believe it has to do with the fact that the servo is never really at Neutral although Half Flap is close.
ORIGINAL: dasintex
Woodie
