Differential Problem....
i'm not sure which forum to post the question, so i will post in this one first....my problem is i have purchased these MK horns and the MK ball bearing clevises...have some money invested in them as they are not cheap... i have always put the hinge point on the hinge line for all control surfaces..however with these products that is not going to be possible due to the b.bearing cleavises not having the reach, and the hard point for the horn not close enough...anyway my question? Is the only thing that is effected by not having these lined up differential on your throws...if so is it not possible to correct the throw amounts with programming....every servo has it's on channel in this case
