need tech help Moki electronic ignition
Hopefully someone with electronics knowledge can help. My Moki 5 cylinder ignition module has stopped sending a signal to one cylinder's spark coil. I've checked for basic coninuity and power but I don't have the knowledge to check individual electronic components on the circuit boards. If someone could help I'd really appreciate it as there's no communication at all from the factory. I assume it's supplied to Moki from a vendor but I can't find out who that may be. A replacement unit is an option but at a very steep price.
Let me know if I might send the module to someone on RCU or possibly tell me where else I should try. I've isolated the problem to the module since a substitution from a friend shows that everything else in the ignition system is normal.
Thanks, Mitch
Thanks, Mitch
