Servo Horn Screws?
Servo Horn Screws?
Hi guys,
This is the first time i've had to mount a servo horn this way. What kind of screws / nuts and bolts do I use to mount my servo horn? Where do I get them and what size are they? They also look like Allen head bolts. I have the exact same horn that's in the pic.
RE: Servo Horn Screws?
ORIGINAL: drube
Hi guys,
[img][/img]
Hi guys,
[img][/img]
I don't understand why they would need to know the servo make and model? I'm looking for the 4 Allen head screws which could be used on any servo I would think. I will try microfastners to see what they have.
WA
That looks like a custom control horn mounted to a standard all round horn with 4 screws? If so, the allen head screws would be the same size as a ball link.
ORIGINAL: drube
Yeah, this is the first time i've seen these horns. It's what came with my Aerobeez 30cc Sbach. I agree that it's mounted on a round horn, I will check to see if my ball link screws will fit.. They may be too long though.
ORIGINAL: BuschBarber
I thought you were referring to the scree that holds on the servo arm to the servo output gear. I understand now that you meant the bolt on adapter arm.
ORIGINAL: drube
ORIGINAL: karlik
ORIGINAL: drube Hi guys,
. Servo - Horn Arm Extension - DIY Alloy, FRP, CF & Nylon
. Servo - Horn Arm Spline Count and Inter Brand Compatibility
Much more information available under sub section
"Servo - Alterations, Calculators, Databases, Leads, Repairs, Convert to an ESC or winch & FAQ."
below
"Radio Systems, Accessories, Alterations and FAQ" at
Alan's Hobby, Model & RC FAQ Web Links
Alan T.
Moderator
I used those on a 50CC Commander (review should be published here over the next couple days)
one thing I did slightly differently, your mileage may vary:
I installed the screws from the bottom of the servo arm, with the nuts on top. (the nuts are where the screw heads are in your pic)
this eliminates the possibility of the screws interfering with the servo body (if they are too long) and makes it obvious if a nut should come loose and fall off.
(use locktite on them too )
Raptureboy: these are used on larger airplanes where a longer servo arm (than standard) is desired. they're typically stronger too.
