DX7s & Radian Pro
I then downloaded the manual from the PZ website and again there is no specific set up in the manual for any radio (unlike some other PZ products).
There is a set up for the older DX7 and DX7se, here
http://www.horizonhobby.com/pdf/Radi..._DX7_setup.pdf
that may work, but I have never used these older model transmitters so I can't confirm how similar they are in programming to a newer 7S.
It is probably a good starting point though.. Just double check everything works in the correct direction before flying..
Did you get it sorted?
Unfortunately I am away from home for another 2 weeks but if you still don't have an answer when I get back, I will download the Radian Pro setup file to my DX8 and then experiment with putting them into my DX7S manually and post the results and settings here for you.
CT
I have cobbled up a set up but have not yet tried it. This is what I have: Gear 0 ailerons up, Flaps drops elevator for each flap drop, FM1 adds rudder to ailerons, Hold raises flaps & ailerons, Aux 2 dials flaps & ailerons up, Rudder DR activates all 3 DR/Expo to high and Trainer hold for throttle cut. Comments?
Ok I downloaded the Radian Pro setup to my DX8 and settings are as follows.
I was going to transfer them manually to the DX7S to see how they apply, but don't have any spare model memories left..
hope that gives you some ideas.
Wing Type - 2 Ail / 1 Flap
Tail Normal
Switch Selection
Trainer - Inh
F Mode - Inh
Gear - Inh
L Trim - Inh
Flaps - Flaps
Mix - Inh
Aux2 - Aux 2
R Trim - Inh
Knob - Aux3
Servo Set up
Travel - all 100%
SubTrim - all 0
Reverse - Right Ail, Elevator, Rudder, Left Ail (all others normal)
No Dual Rates or Expo - everything is 100%
Differential - Inh
Throttle Cut and Throttle Curve - Inh
Flap System
Norm - Flap 50% - Elev 0%
Mid - Flap 0% - Elev 15%
Land - Flaps -80% - Elev 25%
Speed Norm - Sw Flap
Mixing -
Mix 1
Flp > LAL
Rate 0%
-100%
Offset 0%
Trim Inh
Sw Gear1
Mix 2
AX2 >LAL
Rate 25%
25%
Offset 0%
Trim - Inh
Sw - On
Mix 3
Ax2 > FLP
Rate 25%
25%
Offset - 0%
Trim - Inh
Sw On
Mix 4, 5 & 6 - Inh
Tail Normal
Switch Selection
Trainer - Inh
F Mode - Inh
Gear - Inh
L Trim - Inh
Flaps - Flaps
Mix - Inh
Aux2 - Aux 2
R Trim - Inh
Knob - Aux3
Servo Set up
Travel - all 100%
SubTrim - all 0
Differential - Inh
Flap System
Mixing -
Mix 1
Flp > LAL
Rate 0%
-100%
Offset 0%
Trim Inh
Sw Gear1
Mix 2
AX2 >LAL
Rate 25%
25%
Offset 0%
Trim - Inh
Sw - On
Mix 3
Ax2 > FLP
Rate 25%
25%
Offset - 0%
Trim - Inh
Sw On
Mix 4, 5 & 6 - Inh
