Futaba R7008SB Receiver mode changing problem.
MB, CANADA
I am trying to change my receiver from the defaulted mode a to mode b in order to use channel 8 for S-Bus duties. I am able to enter into the mode changing part and with each press of the Mode/Link button I can see the flashing light change it's pattern of flashes which displays which mode it's programmed to. Then upon pressing and holding it changes to a solid color. Then when I let go of the button and cycle the power off and then on, it simply powers up, which I then turn it off and enter into the programming mode to confirm the mode change and once again it flashes out a 1 flash blink to display it's mode which is still in mode a. I have 2 of the same receivers and both do this when I attempt to change modes, so I figure I'm doing something wrong? I am lost as to how to do it? Any help would be appreciated!
