Emaxx transmitter problem
my TQ3 transmitter is giving me a problem. as you know, there is a 70/30 or 50/50 switch that is next to the steering control. most of the time I run 50/50, but I also like the 70/30 setting. when I switch to 70/30 the throttle trim pot needs to be adjusted, but I can't get it to the neutral position, the pot adjusts normally, but it won't adjust to the neutral position so the motors stop. what can I do?
I did not know that. I have another Emaxx that I use at 70/30, all I have to do is adjust the throttle trim and it's good to go. I will reset the esc with the control set at 70?30 and let you know what happens. THANKS SO MUCH!!
