14sga voltage hook up
I been watching videos on you tube on hooking up the voltage sensor to the 70008SB one has just a cable to plug into the voltage port and then to the battery the other one has a resister and that has to be sodder on witch one is wright
Here is a thread on how to 'DIY' Futaba voltage cable. The resistor you mention is actually a fuse.
http://www.daddyhobby.com/forum/showthread.php?t=80625
Woodie
Woodie
