DX7 - Horizon Blade Mach 25
Old 12-06-2019, 05:51 AM
paultzr
Default DX7 - Horizon Blade Mach 25
Hi All
Looking for some help in programming my Spektrum DX7 to control a Blade Mach 25 drone. The manual provided with the drone makes a quick reference to programming a DX7 but I can't find the features in my DX7 .
The manual states for a DX7:
Channel Assign [NEXT]
Gear = B
Aux = 1
Servo Setup : normal
Throttle cut : Switch H
Flight mode
B-switch 0 = Stability Low Bank Angle
B-switch 1 = Stability High Bank Angle
B-switch 2 = Agility
Bind 1 = Panic Recovery
I have the manual for my DX7 but there is no reference to B-switch (it can only be one switch as it has three position) no idea which is H switch and no idea why they have put NEXT after channel assign?
Has anyone programmed a DX7 for a Blade?
Old 12-07-2019, 08:53 AM
AndyKunz
It's referring to a DX7G2 (black). I take it you have the old gray DX7.
Andy
Old 12-07-2019, 10:27 AM
paultzr
Andy
​​​​​​Yes you are correct DX7 old gray one
