Art-Tech E-Fly Rx bind problem???
I am having a problem with a radio set which originally came from an Art-Tech ARTF EP model.
The Tx is a 4-channel E-Fly one with no serial number but the Art-Tech logo above the central 'On' LED.
The Rx is a very small EFly-6D-M 2-aerial 6-channel set. The Rx has no Bind or Batt channel (6 outputs) but it does have a very small 'reset'-type hole/button on the front panel. I've tried to bind with a plug in the AUX channel and by pressing the reset button but the LED on the Rx continues to flash & doesn't bind
I've looked on-line for a solution but with no result (ditto emailing the original suppliers...). Most advice seems to concern 2-aerial (with Bind channel) or 7-slot 1-aerial Rxs (with Bind channel).
Any help greatly appreciated!!
