Older Servos
FL
Older Servos
I'm getting back into the hobby after a 10 year absence. I have several planes with 72mhz receivers that I'm going to change out for the newer 2.4 ghz models. But do I need to change servos also? Will the older servos function with the newer receiver? Inquiring minds would like to know....
Thanks for your feedback.
No reason they won't work. But why are you changing to 2.4GHz in the first place? 72MHz works just fine and the range is better. But if you are determined to spend the money then one reason to buy new servos is if you are going to A123 batteries. Those older servos may not handle the higher voltage of LiFe as well as newer ones.
My Feedback: (41)
