Throttle Exponential Futaba T6EX ??
The servo for the throttle seems to have exponential. Its slow at the start but when I'm past half way on the stick the speed of the servo increases quite a bit. The problem is there doesn't seem to that exponential feature on the throttle channel 3. I also tried a different servo thinking there may have been a problem with the other but it made no difference!
Has anyone else come across this before?
Having looked at some other forums and checking the mechanical set up and EPA adjustments I think I have solved my problem so it seems you're right, thank you for your input :-)
