Aura 8 binding problem
My Feedback: (23)
FL
Trying to set up an Aura 8 futaba s bus receiver. Everying looks to be hooked up correctly. All I'm getting is
the blue,green and red led's flashing constantly when trying to bind. any suggestion would be appreciated
Use of the config tool, hooked to a PC can help diagnose many issues.
Check out their Wiki for more information, also. https://wiki.flexinnovations.com/wiki/Aura
Normally, for non-Spektrum equipment, bind your RX to the TX first. Then connect the RX to the Aura via sBus.
My Feedback: (23)
FL
Thanks for the reply. Yes, I did bind the receiver and transmitter first. With everything hooked up and I turn on transmitter, insert bind plug into aura and turn on receiver I get all three lights blinking. I was trying to do the quick setup mode
Looks like it is time to hook it up to the a PC and use the Config Tool - it is not seeing the receiver input. I won't be able to respond for a few months, but the guys on this very active thread are really good about helping: https://www.rcgroups.com/forums/show...fficial-Thread
