HELP! 9Z radio question....
I'm working on my H9 Ultrastick 60 now. It is set up for quad flaps.
I'm setting this up as a glider 4 wing servo config..Is this right???
Anyways...I wanted the set up the ail/flap linkages so I plugged the wing servos into their respective slots in the reciever to center them... 1,5,6,7.
I turned on the TX and plugged in the bat to the reciever and the servos go wild. What is going on??
IL
Chris,
On a seven servo receiver you're going to have a pretty tough time setting up this aircraft. I would really recommend going to an 8 or 9 servo receiver.
