antenna down any damage?
RE: antenna down any damage?
ORIGINAL: darryl123
hi
does it do any harm if you leave your antenna down with the radio on? if so how much time would be to much?
hi
Yes, it can harm your output stage due to excessive heating. With the antenna down, the SWR (standing wave ratio) goes way up and the energy normally radiated from the antenna is now dissipated in the output stage and heats up the output transistor. When the heat builds up the failure rate skyrockets, doubles for every 10 degrees C. that the temperature rises. Even raising the antenna one section helps but DOES NOT ELIMINATE the heating, just decreases it a bit as the SWR is still higher than it will be with the antenna fully extended. Whenever possible, run with the antenna fully extended to minimize possible damage.
IL
Don't worry, Joe.
Just look at the definition of the SWR (standing wave ratio) here: http://www.its.bldrdoc.gov/fs-1037/dir-034/_5083.htm. As you can see, to create a "standing wave" you need two waves propagating in opposite direction.
The standing wave has nothing to do with the length of the antenna. The output cascade of the transmitter remains equally loaded with fully extended antenna and when it is collapsed. The length of the antenna only affecting the range of the transmittion.
And you were absolutely right by stating that only harm you may cause is having you plane flying into the tree.
But I do like when people making up stories or giving “scientific explanations†about things. This is usually how fairy tales are born.
CA
In this case, the standing wave issue is not a fairy tale; the two waves do exist. One is the RF source. The other is the reflected wave due the impedance mismatch that is caused by the retracted antenna.
If you do not believe this then measure the temperature of the RF PA transistor with the antenna extended for a few minutes. Then retract or remove the antenna and try again. The RF amp will be MUCH hotter. In a poor design, the transistor can fail (but nowadays that does not seem to happen much).
It is best to minimize the transistor's stress by pulling out a section or two of the antenna. Better yet, use the DSC feature if your R/C system has it.
IL
OK, then.
Let's check out the definition of Impedance: [link]http://www.its.bldrdoc.gov/fs-1037/dir-018/_2678.htm[/link].
It is function of frequency which is remains constant no matter how long or short antenna is.
CA
Assuming that the frequency remains the same (such as in this R/C situation), antenna impedance changes with its physical length. In other words, the required length depends on the frequency and related source impedance loading. Any changes to the required length will impact antenna impedance. A fully extended R/C antenna versus a fully retracted antenna will have substantial impedance differences. Its radiated beam pattern changes too.
As a practical example, a classic 1/2 wave dipole will be nearly 50 ohms (37 ohms typical). Change its length to full wave and the impedance sky rockets to a few thousand ohms. Impedance charts for such experiments are listed in many RF design books.
These sort of RF rules are more complex than simple dictionary definitions. The www.ARRL.org site has a good selection of practical antenna design books that will offer excellent info on SWR/SWVR and impedance. And other good stuff.
My Feedback: (8)
MA
thanks for all the answers.
i had an old futaba that i left on and it burned up. i was wondering if they still will fry if left on?
with all of the features i can see having to bench setup a new model and taking a long time doing it and indoors with the antenna down might take 15 minutes or longer and just losing track of time. so it would be best to have the antenna at least up a few sections working indoors.
thanks
darryl
thanks
darryl
To put things in a very simple context, impedence is the resistance of the output system to the transmission of the radio energy. When you have an output device, like the output transistor, connected to a transmission network, like the antenna and its tuning elements, the transistor "expects" to see a certain amount of impedance to work properly. When the transmission network's impedence equals the impedence the output device "expects", you get the most efficient movement of radio energy into the atmosphere. Antenna length is a significant factor in the impedence of the output circuitry.
I've worked with older mobile communications transmitters where we adjusted the output impedence by adjusting the length of the transmitter antenna.
SWR (Standing Wave Ratio) measures the wave sent down the antenna versus the wave reflected back by the antenna. When it's 1:1, you also have good impedence matching, and most efficient power transmission.
With almost any RC transmitter, you should have the antenna partly-extended if you're turning on the transmitter for a short length of time. If it's on for a long time, then full extension would be recommended.
Please remember that this is a really, really, basic, "quick and dirty" explanation, and omits many of the particularly technical aspects of the subject.
ND
As others have mentioned, YES it does play a big part in it, and will destroy your transmitter eventually.
Ryan
KC0LMO
