Gears for a Futaba 9402 servo
My Feedback: (48)
I stupidly broke the little platic gear in my metal geared 9402 servo. Does anyone know where I can find just that one gear? Servo City doesn't carry them and Tower wants a whopping $57 for the replacement set of gears (which are still good). Any help would be appreciated.
RE: Gears for a Futaba 9402 servo
www.futabarc.com has a chart on the site somewhere cross-referencing the plastic gears in metal gear sets with the gears from plastic gear sets. Use it to figure which plastic gearset has the gear you need.
My Feedback: (48)
Thanks for that info Dr Phil...now if I can just find someone who would carry that gear I will OK...guess I could check with the nearest Hobby Store...sure would love to be on your show
My Feedback: (16)
GA
This is the gear set you need for the little plastic gear
http://www2.towerhobbies.com/cgi-bin...?&I=LXH406&P=V
My Feedback: (48)
Thanks guys...just ordered that set a few minutes ago...thanks again for your help, sure beats having to buy the metal gears when they are perfectly good.
AZ
The trouble is not all metal geared servos have plastic gears that are available in a plastic gear package. In that case call the Futaba service center and complain. They will send you the one you need.
My Feedback: (16)
GA
Futaba routinely uses a plastic gear for the second gear.
It seems that the 9202, 9303, 9201, and 9402 all ue the same plastic second gear.
ORIGINAL: dirtybird
FL
ORIGINAL: Geistware
-Kelly
My Feedback: (16)
GA
How do you get it by itself?
I just ordered 6 sets because I usually break that gear a couple of times a year!
ORIGINAL: RightThrust
The 9206 also uses the same gear. They have a good reason for using a plastic gear for the second gear but I can't remember off hand. You can also get the gear totally by itself. I would bet the digitals of the same size an power use it as well, such as the S9151.
-Kelly
ORIGINAL: Geistware
-Kelly
AZ
The first and second gear in the Futaba metal gear servos I have are plastic. That may be OK for flight loads but if you happen to hit the control on the ground or something the plastic gears are gone. I guess that is the way Futaba planned it. If so Futaba should make the gears available separately. Thats why I complain. The digital servos I have are only available in a $50 gear set or from the service center. Right now I have 13 of the plastic gears so maybe I will be OK for awhile.
ORIGINAL: Geistware
-Kelly
ORIGINAL: Geistware
-Kelly
FL
ORIGINAL: Geistware
HSP78224 T 1M11K20701 S9206 1ST GEAR $1.52 each
HSP78226 1M15E12001 S9206 3RD GEAR 4.86 each
-Kelly
My Feedback: (9)
This might come too late, but www.rcheli.com has just the first plastic black gear for 9402, $2.05.
http://www.ronlund.com/Merchant2/mer..._Code=HSP73804
