ESC Question....suggestions
TN
I am learning. Slowly but sure. Thank you guys ahead of time for the stoooooooopid questions. Dave Blum and I PMed a little bit and he brought up a valid point...
"you also need a speed controler that allows you to adjust the voltage point at which the motor cuts off. If you discharge lithiums below a certain voltage per cell it will damage them."
Can I put something inline with my exhisting GWS -300 ESC ? Or does it in fact require a whole new ESC ? Its not like an aftermarket rev limiter on a car engine.... Can I put it between the ESC and the engine is what I am asking.
If I have to get an all new ESC, which one to use with a 2S-1200 Lipo.?? Where should I cut it off ? Thanks. []
