clicks when i steer
clicks when i steer
hi, my Traxxas electric stampede ran fine for the first few months. the steering was smooth. but now when i steer, it clicks and it doesn't always steer as hard as it used to. whats wrong with it? is it the servo and if so, can i fix it or do i have to replace it???
NY
RE: clicks when i steer
Sounds like you stripped a servo gear, open it up and take a look inside see if it's okay, and while you're at it check all your steering connections. If you stripped a gear you can probably replace the gears, but if you're driving it that hard make sure you have a high quality servo for steering, metal gears with BB's.
