9C & Module
ON, CANADA
9C & Module
hi all,I have 2 Futaba Computer radio(7UAP & 9C this TX rocks)I took the module in my old one witch is on #20 an installed it in the new 9C on #58 It seams to work find here in the house but is it safe to fly ?
I read about it in the book,but just wonna hear other opinions
what is involve in retuning a RX?
Is it worth it or should I get some new RX's?
does anyone know a good source to get a couple of RX retuned(in Canada)?
thx
jeang
thx
jeang
My Feedback: (16)
RE: 9C & Module
Retuning the RX would just involve changing the crystal to match your TX channel. It is not advisable to change RX crystals if you have Futaba RX's and are going from a low band (ch 20) to a high band (ch58). You could probably find someone willing to trade a low band for a high band RX. Or you could buy a Hitec RX which eliminates the low band/ high band issue.
ON, CANADA
RE: 9C & Module
I have one of the Hitec Supreme Univsl RXin ome of my plane.U saying I can put a #58 cristal to match myTX witout any tuning?
jeang
jeang
IL
RE: 9C & Module
Jean,
Trust the manual, they wouldn't tell you incorrectly on what equipment is safe to use. The modules are identical -- in fact they are the same product # and if you were to order a new module for your 7U or your 9C they are the exact same module.
My Feedback: (16)
RE: 9C & Module
Yes, assuming you have a Futaba compatible Hitec RX (they make some for JR too), you can buy a Hitec crystal on the same channel as your Futaba TX and be fine. Hitec RX's do not need to be retuned if you change crystals.
I have a Hitec Slim Supreme in one of the planes I fly with my Futaba 9C.
