Micro Servos--Info Needed
Hi,
I am putting together an Ace Simple Series Corsair, This is a small plane, 36" wingspan. It was reviewed here on RCU, and the reviewer used Hitech HS-81s all around(the plane only takes 3 servos). I was going to go ahead and get the same servos, I was just wondering if these are the best choice, are they reliable, or should I get the HS-81's with Metal Gears, or something else entirerly? Thanks for the info.
Allan
Allan
RE: Micro Servos--Info Needed
They are the same servo just a different gear set. You could use the Ciruss 9 gram servos if you are not over powering the plane. Another choice would be the HS-55 servos.
Dru.
Dru.
WI
Allan,
I have the ACE Corsair and am using the Hitec HS55s, but am using four of them. I put one in each wing half for the aileron instead of the single servo with the cable. I also use the same servos on my ACE ultimate without issue....
Dave
Dave
MA
I'll throw a vote for Blue BMS 371 servos listed here
http://www.av8hobbies.com/blue.html
lighter than hs-55's, more torque output, and only 13 bucks each, can't go wrong.
