Fixing frayed Antenna
OH
I have a freind that has an RX with a Frayed antenna right where it comes out the Rx. He removed the case to expose the frayed area, and hit it with some solder. It seems to be holding, Do you think this is OK? Daz...
My Feedback: (8)
The solder may cause it to break even quicker. All of the stress will be at the point where the solder ends.
Since he can solder, just replace the whole thing. Just cut a piece of small wire the same length as the original
