Need info on cleaning and servicing servos
Where can I find some reference material, articles or advice on cleaning and maintance of servos. I have a couple that are not working smoothly. Before I toss 'em I want to see if they need to be cleaned, or have a broken gear or whatever.
These happen to be Futaba S20 mini servos that have probably been sitting for 4-6 years in a plane I just purchased used.
RE: Need info on cleaning and servicing servos
Solved the servo problem. My wiring was fine. They were just dirty. They have probably been sitting in the plane in the basement of the guy who sold me the package of three planes.
I opened 'em up wiped everything out and poured alcohol through them to remove any film that might have built up over the years. Blew them out, let them air dry by a fan then warmed them with the low setting on the heat gun to drive out any remaining moisture..
Put them back together and they work perfectly. Rock solid and no chatter at all; and strong!
I have some weeks before I will be putting the plane in the air so I will have plenty of time to work them to be sure that they are fine. Any doubt and they come out.
I would prefer to use them as they all fit perfectly. If I replace them I have to start making holders and housings for the servos. I will do that if I need to, but first I am going to try cleaning them and then excercising them over the next few weeks.
AZ
ORIGINAL: aeajr
I heard that from someone else. Had never heard of this magazine before. Would love to get a sample issue, but they don't offer it.
Chechk out www.rcreport.ws
