Airplane servo torque requirements.
My Feedback: (168)
FL
There are many "opinions" about using this or that servo for an aircraft application, but does anyone know just exactly how much pressure is being applied to a control surface by the air when in flight? Is there a formula that will take the area of the control surface, and the speed, and the angle of deflection and come up with a real torque requirement? I suppose then we'd have do do some more math to sort out the servo arm and control horn length. Hmmm, math is not my strong suit. I have a Giant Aeromaster, and before I go out and buy a set of "huge" servos, or some expensive coreless or digital servos, I'd like to know with some degree of security, if it needs nothing more than a batch of Futaba S3001. I dont expect this plane to be winning high level aerobatic contests, but I do expect it to be fully capable of IMAC figures, and fly through them fairly well. All comments appreciated.
Thanks.
Thanks.
My Feedback: (16)
GA
RE: Airplane servo torque requirements.
Try this servo torque calculator.
http://www.geistware.com/rcmodeling/...calculator.xls
AZ
ORIGINAL: Geistware
My Feedback: (16)
GA
Download this viewer from Microsoft.
http://www.microsoft.com/downloads/d...displaylang=EN
ORIGINAL: dirtybird
Do you mind publishing the formula you used for the calculator? I don't have MS Excell
ORIGINAL: Geistware
