alvtr on 8uap
alvtr on 8uap
Im setting up dual servos on my elevators useing the (alvtr) . at full up or down the elevators are even with each other but at half stick one higher then the other. there not even with each other. whats wrong. thanks
alvtr on 8uap
Daren,
It sounds to me like you just have two poorly matched servos. The feedback potentiometers in our servos are never perfectly linear (in fact they are far from it). About the only thing you can do is to swap servos till you find two that are more nearly matched in linearity. This is clearly evident when people gang two servos to the same surface and then wonder why their batteries go down so fast.
