Futaba S9152 Aluminum Horns ??
Hi,
I recently purchased a Futaba S9152 servo and I have been looking for a 2 inch full Aluminum Servo Horn that will fit this servo and have had no luck! I was searching on Futaba’s site and was only able to find horns to fit there standard servos. I was also searching on R/C Universe and found messages of others searching for them and they too came up dry.
Does anyone have any idea where I can buy an aluminum horn to fit this servo?
FL
RE: Futaba S9152 Aluminum Horns ??
I don't know of any metal arms, or any aftermarket arms for these servos. Your only option for an aftermarket arm is through Sure-link who uses the stock plastic wheel that is sanwiched between 2 aluminum arms that he makes. I would advise using the plastic arms that come with the servo, many people have been using them on 40%'s without any issues, you will not break them.
-Kelly Gerber
-Kelly Gerber
Yes I already called them they said at this moment untill the demand calls for them they do not plain to carry them. While I was on the phone I did order all the other arms I needed for my Hitec servos.
