what transmitter has independent servo controls
What transmitter has independent servo control for each servo in a plane with two ailerons? I have discovered that the JR 662 does not. I cannot adjust each side independently for direction and travel. That is the feature I thought I was buying. There must be some transmitters which do this since my old Micropro 8000 could do it.
Malcolm
Malcolm
My Feedback: (7)
RE: what transmitter has independent servo controls
ORIGINAL: ponderosa
Malcolm
Malcolm
I also have a Futaba 9C which allows what you need.
I am fairly sure your transmitter has a Flaperon wing type. If you select this, you will need to plug the right aileron servo into channel 2 and the left aileron servo into channel 6. Then you can adjust each one by its own channel.
