Hitec 5645 digital servo info
Has anybody used the Hitec 5645 digital servo. I understand this servo is not coreless. I have read that you should not set Hitec digital servos past 120% of travel. I plan on using this servo on a hot 120 size plane.
That is correct, neither the 5625 or 5645 are coreless. Their coreless versions are the 5925 and 5945 and are about $35.00 more expensive.
The original Hitec digitals did have a problem with end points past 125%. My understanding is that this problem has been corrected in the new versions. In addition, the newer 5625s and 5645s have been re-statted as 100++ ozs of torgue from 77ozs.
