Servo Jittering
Old 02-06-2005, 03:08 AM
Hornet MX 400
Default Servo Jittering
I have a problem with my servo's jittering. I have Hi Tec 645MG Servo's, when i move one channel, such as rudder left to right, the throttle servo jitters and moves. Moving the throttle does the same to the rudder servo - it jitters and rotates side to side. Any idea what could be causing this? This jittering did not occur with the standard Sanwa servo's that originaly came with the radio.
Any help would be greatly appreciated.
Regards
Jim
Old 02-06-2005, 12:08 PM
dirtybird
Default RE: Servo Jittering
Make sure your battery voltage is what it should be and clean all your connectors. Sometimes a bad switch harness can cause this. The 645's draw a higher current than the Sanyos.
Old 02-07-2005, 06:21 PM
Hornet MX 400
Thanks dirtybird,
I will check all these, change batteries and clean connections and see if the problem persists.
