deans whip antenna
My Feedback: (14)
TX
RE: deans whip antenna
I have one on a Wayne Siewert KI-84 Frank which has a carbon fiber fuselage. The receiver is a Futaba R-129 DP. The Transmitter is a Futaba 9ZAPS WCII and has more than 250 ft antenna collapsed range. Flight range is as far as it is practical to see. I use a Deans connector to hook up to the stub antenna coming from the receiver.
ORIGINAL: Bud Faulkner
I've seen the deans whip antenna used on helicopters but has anyone used one on a plane?
Bud
Bud
Gremlin Castle,
Why the deans connector? Isn't the supplied connector sufficient? I have the Dave Patrick super cub and was considering using the whip. I'm using the futaba super 8 radio. Where is yours placed, in the fuse or exposed? Thanks,
Bud
Forgot to mention...that's a sweet looking plane!
Bud
MN
I know of a lot of people that have used them, I'm just sharing that I did not have good luck with the one I used. You need to cut your antenna of the receiver to a certain length (mine was a hitec 555) and solder it (or use a connector) to the whip.
I only got a range check of about 30 paces with the antenna collapsed, and I'm normally over 50. This was with a Futaba 8uafs transmitter.
Theres too many people using them with good success, I must have gotten a bad one or something.
Thats a very nice Ki-84 Frank, Gremlin Castle. I've had the privledge of touring Wayne's shop and watching them lay up some tail pieces. Pretty awesome line of production they have, and excellent quality.
My Feedback: (14)
TX
Their connector works just fine. I just happened to change out receivers and that was what I had on hand to use for the connector. Look at the picture and you will see a small black dot about 3" behind the canopy. That is the insulator,thewhip doesn't show up well in this picture.
Gremlin Castle,
Bud
Gremlin Castle,
Bud
Thanks Gremlin Castle, I see it now. If my ship ever comes in i'll buy Waynes P51 kit, of course if it does come in i'll be at the airport that day
Bud
Bud
My Feedback: (14)
TX
I think my ship came in and rammed the dock wrecking it and then drifted back out in the harbor where it sank blocking the shipping channel.
I think that you would be more than happy with anything that Wayne produced.
Bud
Bud
