Multiplex transmitter
AZ
If you fly mode 2 and grip the transmitter in your hand as I do, your thumb forms an angle with the stick gimbal that results in an inadvertent up elevator with left aileron and down elevator with right aileron. I am told that on the Multiplex transmitter you can rotate the stick gimbal to compensate for this.
I would appreciate hearing from someone that has one of the transmitters and can confirm this
AZ
RE: Multiplex transmitter
Thanks. Too bad no one has never done that before. I just lost an airplane when I had to make a hard right aileron correction close to the ground. I always wondered why it was easier for me to turn left than right.
