MPI Switches with VOltage indicator
HI All,
I am setting up a new 30% Edge. I will be running Hitec Digitals all around, powered by a 6 volt NiMH pack. I have used the Maxx Products (MPI) switch in the past with good results, but I'm wondering if I should be looking at something else for this application. I like teh MPE switch because it has a charging port and a green/yellow/red LED votage indicator on it as well. I have also read that the the electrical component most prone to failure in a RC aircraft installation is the switch, has anyone had any problems with these?
