Help with gy401 and 8 non super
Hello.
I have a Futaba 8UAP non super and I´d like to know if it can work perfectly with GY401. I read the FAQ at futaba site and they say I just have to adjust the ATV, but I don´t understand this. Will I be able to change from a switch from HH mode to non HH mode? And to change gain?
I want to buy this gyro but not another radio!!!
Any help and oppinions are really appreciated.
Thanks a lot in advance:
Daniel Maia
Daniel Maia
RE: Help with gy401 and 8 non super
Thanks for your reply!
The end point or the ATV settings? Switching the fear switch will make it change from hh mode to non hh? And changind the ATV will change the gain?
Once again thanks a lot.
Best regards:
Daniel Maia
Best regards:
Daniel Maia
The single wire goes into a channel controlled by a toggle. Lets say up is Heading Hold and down is Normal (rate mode)
When you set the end point up to 50 percent of available up throw you have Heading Hold mode with 50 percent gain. The closer the end point for the up position the higher the gain in HH mode.
Same with down, set half the available throw and you get Normal mode with half the gain, the higher you set the down atv, the higher the gain in Normal mode.
If you think of that switch as a knob, full right would be heading hold with 100 percent gain, as you rotate the knob to the left the gain decreases, when you hit mid point on the knob now you have zero gain in either mode, as you go past 1/2 way it switches the gyro to normal mode and as you keep turning to the left gain increases in normal mode till you reach the end where you have 100 precent gain in Normal. Back to the switch, your end point just sets two points on that knob, one somewhere to the left which is your normal mode and gain, and one point somewhere to the right which is heading hold and the gain percentage. Vary that point and you vary the gain but with a switch your just toggleing back and forth between those two points.
You do have to ALWAYS turn on the TX first and put the switch in HH mode and then turn on the gyro and wait for it to init and the light will come on steady. From there you can switch back and forth but like I said, once you fly HH mode you won't go back.
Thanks a lot barracudahockey.
Now I understood it completely. I will definetly buy this great gyro and keep my radio!
Best regards:
Daniel Maia
Best regards:
Daniel Maia
