difference between futaba 8uap VS 8uaps
Administrator
My Feedback: (12)
8UAP vs 8UAPS
*Red markings on the silver and black face plate identify this radio as an 8U** S over the older model, 8U**. This model is also known as the Super 8.
*** New Features Over The Standard 8UAF/P ***
Digital trim buttons now have a beeper when moved past center.
Trainer function now has function/normal modes
Stop watch now has a power-switch ON mode
+FS data direction changes automatically when throttle channel dir is rev.
D/R and Expo are now set individually for left/right and up/down.
- HELI mode -- in condition mode 3 rates are available.
5 normal mixes and two 5-point mixes
Snap roll function has safety mode
+2nd aileron servo programmable so you can use a 5ch radio & twin servos
(+ = see comments for additional information)
*** HELICOPTER ***
4 swashplate types -- SWH1 (std) SWH2 (CCPM) SWH4, SR3, SN3
Offset rate changes with digitrim when function is activated.
3 offset rates now available (8u only had 2)
Gyro mixing ("Gx") has normal and condition modes; the normal mode moves to swA automatically when invert switch is active.
Governor mixing now available and has normal and condition modes.
*** HELICOPTER ***
